Results 1 to 11 of 11
  1. i am using dvdlab pro to make a dvd with tv eps on it and i try and add chapters to each ep but it only adds them to the first ep and none of the others. and nero gives me fille allocation errors. I did auto chapter tool on each ep and it should work but it doesn't. Any advice would be appreciated.
  2. Member CaZeek's Avatar
    Aug 2003
    NJ, DC, or Baltimore
    I've never had a problem like this, but maybe you could try frame indexing the chapters? You can do them individually, or you can just check off the "frame index all chapters" box when you compile the DVD.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It will make the DVD menus more complex, but try putting each episode in it's own title set (VTS). Each can have it's own menu linked from the main (VMG) menu. Should fix your problem.
    Read my blog here.
  4. they are all under there on vts the setup is like so:
    Firstplay intro
    vgm menu
    link to all the episodes and then and the end it links back to the menu
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Are they in a single VTS, or a VTS each ?
    Read my blog here.
  6. they a re all in there on vts
    Apr 2004
    Miskatonic U
    It sounds like you have them all in one VTS. You need to add a new VTS for episode two, three etc. You should then have VTS 1, VTS 2 etc down the left hand tree. Add you chapter menus for each episode into that episode's VTS.
    Read my blog here.
  8. i meant that they all have there on vts its like this
    DISC INTRO
    VMG MENU
    VTS 1
    Movie 1
    VTS 2
    Movie 2
    VTS 3
    movie 3
    Vts 4
    movie 4
    and all the movies link back to the vmg menu
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    In each VTS, add a chapter menu for that episode. Link the VMG menu to the chapter menu.
    Read my blog here.
  10. i didn't want a chapter menu i just wanted to be able to change the chapters using the next button on the remote
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Go to the Mediachance forums and look at the DVD Lab Pro forum. Most likely to find the answer you seek there.
    http://www.mmbforums.com/
    Read my blog here.
