  1. Member CaZeek's Avatar
    Aug 2003
    NJ, DC, or Baltimore
    Hello,
    I made some disk art using the templates provided in the previous Epson R200 Adobe template thread. I now want to print the DVDs. Can I print directly from Photoshop? If not, is there a way to import a high resolution image in Epson's software without having to try to manually resize it to line up with the software's template?
    Basically any solution will help me out. I have PSD CD images in 200-300dpi that I want to print on to DVDs. What's the best way to actually do it?
    Sorry if this has been answered already.. I tried reading every post in the previous 2 threads, and I could not find a clear answer.
    Thanks a lot
  2. Just save the images and select them in epson photocd. NOW if they are true 200-300 dpi make sure they are actual size of the disc if they are downsampled or tweaked while saving you will have to stretch them out or in depending on what you did.
    I just create the artwork at 1394 pixels by 1394 pixels at 300 dpi and when I plop them into epson cd its perfect no resizing or anything. That is using the 118 cm outter diameter of my printables (may vary depending on media)
  3. I think any size above 1200 x 1200 will be imported correctly. Even if you use 100 dpi.
