Hello,
When I watch the slideshow on PC monitor the images are superb, but on TV the color is whashed and the quality is not good.
IMAGES
- NTSC DV 720x480
- Resolution: 150 pixels/inch
ON PREMIERE
- Variable bitrate - 8000(max), 7500(avg), 7000(min)
- NTSC Progressive(no field)
What is the problem ?
Can u help me?
Thanks,
Wood
What sort of quality issues, apart from washed out colour ?
Generally, most people set their brightness and contrast too high, and their colours either too rich, or not rich enough. If the colours look good on the PC, and washed out on the TV, I'd suggest it is a settings issue. Either your monitor has the colours set too strong, or your TV not strong enough.
As for quality issues, PC monitors are progressive, TV displays (tubes) are interlaced. Fine horizontal lines can flicker or cause moire effects which won't be apparent on your PC. Usually a gentle gaussion blur (only slight) or small vertical motion blur will fix these problems.Read my blog here.
The vertival motion blur = 2 , fixed the problem.
Thanks,
Wood -
Also, it's very important to encode progressive, not interlaced, when doing photo slideshows for DVD. All the flickering vanishes when you do.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
Help with video slideshow
By Aura in forum EditingReplies: 10Last Post: 8th Feb 2010, 05:44 -
Slideshow Help
By GuyinBrown in forum Authoring (DVD)Replies: 4Last Post: 27th Oct 2009, 21:38 -
slideshow creator
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2009, 09:39 -
Slideshow question
By jjis in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 02:27
