I have a series of 4 xvid files- files 1, 3, and 4 converted no prob with xilisoft (they were all encoded by the same source).
however, file 2 'converts' after 2-3 seconds as only a 30k file (no matter what format I choose)
I tried TMPENC but after about 2 hours it crashes as well
I opened it with GSpot, everything seems normal there
I'm stumped
Results 1 to 16 of 16
see "check for bad frames" in search
ok, will do- forgot to mention I tried dvd2svcd with cinema craft encoder as well, it get to a certain point and just freezes
ok, got ac3fix running (the gui simply doesnt work at all, waste of time there), and it has been runnng for 5 minutes, currently on frame 1500, says every frame has 30-60k or 'current wrongness' whatever that means
tried opening the file with virtualdubmod- gives me a warning of '
improper VBR encoding in the source avi file (audio stream 1) and asks to re-write the file? I can't figure out how to save the audio in vdubmod, there is no audio menu like in vdub -
you didnt check for bad frames and it sounds like it is a mp3 file , not a ac3 file ... and you are wasting your time using ac3fix to to fix a mp3 file ...
check for bad frames (see the many guides)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
computer froze trying to check for bad frames... sigh this is just impossible to figure out
I skipped ahead to files 4-5-6 to make a dvd, tmpeg dvd crashes with an error that there is an 'illegal ac3 codec' ?
I've tried half a dozen different programs so far, no dice -
I had the same type of avi that would crash tmpgenc and virtualdub,what i did was run the avi thru divxfix and and had cut out bad parts checked,after it was finished the file wont play in wmp but you can load it in virtualdub and frameserve it to tmpgenc.
re-obtained the source file- tmpgenec crashes at about 50%- invalid pointer operation
Try installing ffdshow. I've hd xvids that don't work with the official codec and ones that don't work with ffdshow but between them managed to cover most.
Also if you haven't already done so make sure you have the latest version of xvid.
I've also had to pass some files through vdub and create a new avi that can then be re-encoded some times.
Good luck but sometime these file are damaged beyond fixing. Especially if they have been downloaded -
maybe a miracle here- when tmpgenc crashed again after a few hours (I separated the audio track with Goldwave following the guide posted here), it started right up again from the first frame! It still showed 50% in the status bar, but did the entire file again.
Now it outputted a file in the correct size but in unknow format, but would't go to 'finished/stop' status (clock just kept going at 100%)
I re-named the file with a .mpg extension since it wouldn't open in media players, and am trying to output a dvd using that file right now:
if this works, I will redo the DVD with menus, etc. ,, once the file is confirmed
cross your fingers
How to convert a H264 TS File to XviD
By onesikgypo in forum Video ConversionReplies: 9Last Post: 6th Aug 2009, 14:15 -
New MKV File-convertxtodvd won't convert it.
By jbitakis in forum Video ConversionReplies: 17Last Post: 4th Feb 2009, 14:51 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
RMVB file won't convert?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 19:34 -
What is the best freeware to convert to an XviD file.
By amadeira in forum DVD RippingReplies: 2Last Post: 21st Sep 2007, 23:28
