Hello all!
Have downloaded the lastest drivers+PVR software.
Am using Windows XP PRO with SP2 installed.
2 Problems:
1.Since I installed the above mentioned I don't hear anything for the card!I don't know why.It's set to AUX as I installed it physically.
2.There's a distortion in the form of a retrangle in the right side of the preview box.When zooming to full screen,almost of the distortion disappears,except fot about 2 Milimeters.
Does anyone have a solution to these problems?
Thanks in advance,
Yohai.
i assume you connected the aux connector from the expert card to your sound card aux.Did you set it to aux in the pvr software and checked in system/sounds and audio devices that its set to aux?
It appears to be some faulty software configuration within the OS.
I bumped into a reply on www.tv-cards.com:
If all the hardware connections are OK.
Maybe the problem is caused by driver, application or SP2 ?
Try the AMCAP to verify:
http://noeld.com/programs.asp?cat=video
Run AMCAP -> "Cross bar" -> "Audio Decoder Output" ->
The input is blank means muted, select "Tuner audio input"
Leadtek Winfast 2000XP Expert... No sound all of a sudden!:
http://www.tv-cards.com/messageboard/viewtopic.php?p=25163#25163
AMCAP has somehow awaken my sound back to action!Ubsolutely amazing!That was the whole story.
And to think that in order to deny hardware problems I opened my PC and moved the card to another PC slot!
Just amazing!
Thanks for the reply,
Yohai.
TV2000 XP Expert No Sound
By cbr549 in forum Capturing and VCRReplies: 5Last Post: 5th Dec 2010, 12:29 -
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 11:32 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
