Results 1 to 20 of 20
  1. how can i delete my old post ??is there any way to delete locked posts
  2. Banned
    Sep 2004
    Inner Circle of Thought
    You cannot delete your post.
    read the rules
    You can post new topics in this forum
    You can reply to topics in this forum
    You can edit your posts in this forum
    You cannot delete your posts in this forum
    You can vote in polls in this forum
  3. Member adam's Avatar
    Sep 2000
    Regular users don't have the ability to delete posts or edit locked posts. If there is a post of yours that you want removed just make a reply in it stating so and usually one of the moderators will stumble on it. Otherwise you can PM any moderator and ask us to remove it.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    pm me if you want a post removed for some reason
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    or what he said 1 sec before i did
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Oohhh Boy....time to search to see what he wants removed...HURRY....
  7. So find the post and hit "Edit". Then obliterate the dumb thing you said and replace it with the brilliant thing you just thought of. Easy. I do it all the time.
    Except for locked threads, of course. Then it may come down to bribing a MOD.
    Pull! Bang! Darn!
  8. ...and if you try to bribe a mod, you'll get yourself banned. Then it won't matter.
    Problem solved.
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    i can be bribed !
  10. I can also be bribed. Yellow or red cards against your enemy, topics locked, what me to look the other way? Can be done! Just for a small donation to my PayPal account.
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    i am cheaper -- always 10% below your lowest quote ..
    You are in breach of the forum rules and are being banned. Now I control the corrupt mod industry!
    / Moderator pacmania_2001
  12. think you need to post this a few more times. i don't think anyone noticed it yet...get the hint?
    How Big A Boy Are Ya?
  13. Originally Posted by ghoster
    lol
    Mar 2002
    Milwaukee, WI USA
    The FAQ should be updated. It says you can edit or delete your posts but then only describes how to edit.
    https://www.videohelp.com/forum/faq.php#15
  15. Video Restorer lordsmurf's Avatar
    That FAQ is the standard phpbb coded one.
  16. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ... and the ability to delete your posts is a customisable option at the discretion of the forum admin, and Baldrick has decided that we mere mortals shant have that ability.
    If in doubt, Google it.
  17. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I thought you could delete your own post, but only if nobody else has responded to it.
    Buy My Books
  18. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That's one option, but it's turned off here.
  19. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    You can edit your own posts as far as I know, but ive not know any memers (other than mods) than were able to delete a post. I think its always been that way.
    If I need to delete a post, I just leave it with the word EDIT. Not much else you can do.
