despite burning several dvd's i have noticed it is now taking twice as long as it used to. I've checked my dma setting and for some reason(unknown)despite saying dma if available it is currently using PIO.
It used to use DMA but has changed on its own as daft as that sounds.
Any help would be appreciated
Go into the device manager and uninstall the ide channel it is on and reboot.
When rebooted, windows will redetect the drive and it will be in dma mode. -
After wrestling with the same problem (ide channel resets itself to using PIO instead of the requested DMA, and subsequent refusal to use anything but PIO), I searched this site, and after finding nothing of any help, I googled it and found that Windows resets itself to PIO after 6 device errors (which can be caused by a scratched or dirty DVD), and will no longer allow you to set it back to DMA.
To save space, it would be easier for you to just look at the web pages I found:
The best description of the problem (with solutions)
http://www.michna.com/kb/WxDMA.htm
Microsoft's answer to the problem (with solutions) http://support.microsoft.com/?kbid=817472 -
Did you not read what I said just above you?Originally Posted by VegasBud
I already said how to fix it. -
Yes, Bazooka, I did read what you wrote.
If you would have read the links I posted, you would see that there are ways to prevent it from happening again, or at least the frequency of it happening. Plus I've found that understanding why something happens can be just as useful as a quick solution.
PIO Mode After Encoding & Other Stuff
By Tom Saurus in forum ComputerReplies: 66Last Post: 20th Jul 2011, 17:38 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
PIO mode detector???
By AlecWest in forum DVD & Blu-ray WritersReplies: 12Last Post: 12th May 2010, 15:49 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 16:26 -
Question? new drive jumping into PIO Mode?
By BiZzZzaaR in forum DVD & Blu-ray WritersReplies: 6Last Post: 13th Jun 2007, 20:37
