just curious, and not sure where to post...
I'm trying to find out if there's any player that are hackable so that you could have a custom text or logo displayed while the player is idle.
for example, the Apex 1010 I have, after waiting on a menu or a paused video for a while, goes to a screensaver of the Apex logo bouncing around the screen.
are there any players that can be hacked to insert a custom text to bounce around? prefereably cheap ones?
any info / links appreciated.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I just saw a post about this in the last week or so. I'll do some digging.
Edit: https://www.videohelp.com/forum/viewtopic.php?t=245896 -
The screen dump is in the firmware. In many
cases the firmware is flashable so the answer
is yes but
1) You may need to befriend someone with a eprom burner
(if you don't have a unit that has a Flash Rom)
2) You will need the orig. code
The early Apex's were so popular, some ppl wrote
screen dumping software for them. The AD100A comes to mind -
offline - aren't some of them reflashable by copying the new firmware to CD, then starting the unit with the CD in place? I know I have seen a procedure for this somewhere. I don't think all units are that way, but some are.
I had a type of Apex that had a eprom.
I got the code from china, stole a background I wanted and
had a mate combine and burn it for me. Some firmware is just
cheaply stored on a rom chip - you have to replace those (approx $40).
Depends on the player as you said.
Here is an example of what you are looking for I think:
http://www.nerd-out.com/darrenk/Backgrounds/Background.htm
Set Default Player for FLV format?
By schwine in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2013, 11:21 -
Set-top Blu-ray player that can play IFO
By AndyRough in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Sep 2011, 05:35 -
Looking for compact set-top DVD player
By Djinn987 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jun 2010, 15:20 -
PC drive in set top DVD player?
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2009, 14:59 -
portable media center in addition to set-top player?
By celchlepp in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:30
