If I have a client DVD that features more than one .vob, it plays back fine and seamlessly when being played on any of my DVD players or when captured to the PC via capture cards.
But if I copy the .vobs to my HD (this is not copy-protected stuff) or use any number of software tools to rip the .vobs and then play them back in a wide assortment of NLEs for editing, including the Womble ones, there is always a visible and audible gap when crossing from one .vob to the next, even after re-encoding. It's brief but the visual jerk and audio gap that occurs is always enough to distract from the flow of the content.
How do people handle these gaps? I don't want to have to edit out frames or partial frames.
Thanks.
Rip the movie back to a SINGLE VOB file.
Thanks LS, that works.
GShelley61 suggested that I join them into one file using FileJoiner and that worked but only if I did it from the actual DVD. If I did it from vobs that had been copied to the HD the gaps came back.
I wonder what it is about keeping the vob files separate on a hard drive that gives gaps.
How to Handle HD Video
By djtech2k7 in forum Newbie / General discussionsReplies: 5Last Post: 26th Mar 2012, 20:50 -
Is there any software recommend to handle TS in the following way?
By ihmcjacky in forum Video ConversionReplies: 11Last Post: 2nd Dec 2010, 13:29 -
Will this computer handle the BMIP?
By WILDWAYNE001 in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2010, 19:46 -
How do presets handle video...
By bsuska in forum Video ConversionReplies: 2Last Post: 23rd Dec 2009, 09:11 -
BenQ firmware can't handle 8X DL
By miamicanes in forum DVD & Blu-ray WritersReplies: 8Last Post: 5th Feb 2008, 13:27
