Hi All,
Got some loot for a DVD burner finally. I want to be able to burn both DVD- and DVD+R.. Can someone tell me what the best dual layared DVD burner on the market is? THANKS!!
Shawn
Results 1 to 30 of 41
For real????? I have had a NEC brand for the last year and everyone i talk to says they only have a one year lifespanOriginally Posted by soundforbjt
I dont think there is a "best"..lol..but i do ok with an LG and Hp, I always buy whats cheap. If you look over in the DVD burners <<< many people leave comments on them.
Liteon at walmart ... $100 bucks ... works good for me
$100 is too high for Liteon; see Newegg.com.
I would also vote for NEC 3500 with a close second being Pioneer 108. They both burn good media flawlessly.Still a few bugs in the system... -
Pioneer 108 (A08)
kewl thanks for the tips so far? someone mentioned to look in DVD BURNERS and view people reviews? where is that at? I see DVD Writers..
Capmaster..Originally Posted by Capmaster
is this the one you suggested????
http://www.compusa.com/products/product_info.asp?product_code=314917&pfp=BROWSE -
Most burners now days burn Dvd-r or Dvd+r. My suggestion is to buy the fastest and dual layer burner. I have Pioneer's 108, fast cheap great all around burner i paid $89.00 but I have seen it for less. As for the dual layer I know the media is still a bit high in price, it will come down.
yo tattman!!Originally Posted by Tattman
$89 bucks?? where? i am at comp usa's site (the link i gave above) and they have it listed at $119.99 (after $30 rebate) so it would cost me $150 up front.. -
ok thanks. i found it at best buy for 89 bucks after rebate....Thanks for the input everone!!
\m/
Rock on! -
I'll second the Pioneer choice. I have a 106 and it has burned everything I've put in itOriginally Posted by Capmaster
Pioneer, LiteOn, LG
1. BenQ DW1620: Very good burn quality, fast, very good media support and firmware support from BenQ, bitsetting for all plus formats, support for media quality scanning. "Editor's choice" at both cdfreaks and cdrinfo.
2. LG GSA-4163B: Fast and good for rewriting with 8x DVD+RW, 6x DVD-RW and 5x DVD-RAM, very fast at 16x DVD±R thanks to PCAV, support bitsetting for DVD+R and DVD+R DL.
3. NEC ND-3500A: Performs well with both DVD+R/RW and DVD-R/RW, lots of "unofficial" firmwares and tools available. -
Are any of these available external as USB?? If not, what would the recomendations be for a USB external?? Thanks. John
Buy a combo(USB/Firewire) external enclosure for $40USD.Originally Posted by johncat
www.meritline.com/firewire-usb-external-enclosure-5-25-cd-dvd-drive-hdd.html -
I got this one ... I put my Sony DRU-500A in it ... works with my Compaq Presario 1210US Laptop and my Dell 5150 Laptop.
http://www.supermediastore.com/bytecc-me-320u2.html
Bytecc USB 2.0 External Enclosure for 5.25 / 3.5 Inch HDD/Device, w/ Fan, Silver, Retail (ME-320U2)
Ratings:
Product Code: HDW10X0031-001
Manufacturer: Bytecc
Mfr part #: This External Case is a portable storage drive case that incorporates the new USB 2.0 High Speed interface! This case provides an easy and fast way to add more storage to a computer. The hot-swappable Plug and Play feature gives anyone great convenience on the road or when using the drive with different computers. This drive is compatible with Apple Macintosh and Windows personal computers. more... -
The NEC 3500A is a good drive (I am currently using Liggy's 2.18 modified firmware - check out the NEC subforum (under Hardware recorders) at http://club.cdfreaks.com for info on many different firmwares.
The BenQ 1620 is also suppose to be a good drive (a bit faster, supports error scanning, and better "official" firmware support).
The nec still appears to have an advantage with -R media, but the BenQ is catching up fast.
If purchasing an external case, I would highly advise a combo unit (firewire/USB 2.0). The NEC drive has had some issues with firewire enclosures that use the Oxford 911 chipset, and seems to work better with the prolific chip based solutions.
Also, very few people have had success recording at 16x via USB 2.0 connections. There are quite a few threads about external cases and the NEC 3500A and BenQ 1620 over at http://club.cdfreaks.comSome people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
ok. HELP!!!
I went out today and bought that Pioneer DVR- A08XL Internal DVD/DC Writer.
I removed my old DVD/CD Writer That originally came with my DELL 2400.. The old drive was set as the MASTER... By default the new drive was set as the master also.. So i popped it in correctly, got all the connections tight....I booted up and got this error SECONDARY DRIVE 1 NOT FOUND, STRIKE THE F1 KEY TO CONTINUE OR F2 FOR SETUP.
I wasnt sure what to do. So i hit continue. When i went into windows explorer. Neither of my CD Rom drives are recognizable.. I have one regular CD ROM drive and the new one which i just bought....
In the box, it came with 2 CD's.. But they are labled exactly the same.. same exact program list on both CD's. I figured it would have came with a floppy or some drivers for it.. but nothing... Anyone help me out? I havent done or tried anything else yet.. -
if the retail drive you purchased came with a IDE CABLE then use that instead of the one you originally had. you can try posting your problem at the PIONEER FORUM at cdfreaks.com.
http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=30&f=87 -
Pioneer DVR-108 $92.00 free shipping, at winlandcomputer.com,
http://www.winlandcomputer.com/scripts/listbymfg.asp?MFG=Pion
I'm sure that if you search around on the net. you probably can even find it cheaper. The only problem this is only the dvd burner, doesn't come with any useless outdated software that the expensive ones do. -
buy a new 80 PIN IDE CABLE...
some dell pc's IDE Cable is a cable select one which wouldn't be compatible with the 108 drive set on master.
how much do those normally run??? i mean.. it looks like this cable goes to my other CD rom drive too........dont have much expierince with this....Originally Posted by budz
hmm wont work on slave eh??Originally Posted by budz
guess i will put the old dvd burner back in for now until someone gives me info how to fix this.. if its that IDE cable i need (80).. then guess i have to get one eh? sucks my regular CD rom drive isnt getting recognized though.. -
YepOriginally Posted by Evhmoon
Edit: Oops
A little late with this reply.
Try removing the jumper entirely
I would like to buy a VCR S-VHS Panasonic...can someone suggest me which of
By Giasan in forum RestorationReplies: 2Last Post: 12th Nov 2011, 17:50 -
I would like to buy one of these two VCR panasonic ...can someone suggest
By Giasan in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 11:41 -
Please suggest a simple portable USB DVD burner to purchase in the US
By suirauqa in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Jun 2010, 08:49 -
Which External Dvd Burner To buy???
By ofield in forum DVD & Blu-ray WritersReplies: 9Last Post: 22nd Dec 2007, 02:10 -
Pls suggest a good inexpensive DVD burner
By phildis in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Nov 2007, 12:29
