i have version 1.5.12 or whatever the last one worked fine all the time then thought last night i go check up on the version 2 that we all been waiting on after much hassle gettin installed with xp service pack 2 guff i get it workin so i have both versions on my pc after frist conv avi 2 dvd it crashes at the burn stage which is no big deal did it manually
but the real problem is that after a reboot due to the crash no version works at all neeed help !!!!!!!!
Do you get any errors?
Hi
Chrissyboy i have just sent you an email regarding a similar problem to geordiedoors.
When i try and start either version up it just won't start up, if you CTRL/ALT/DEL quickly it has generated a dr watson error in applications.
It looks linked to the net framework service pack if thats any help
Sent you that log.
cheers -
Thanks for the info. I have replied.
Muxman ver 1.0.3 Error?
By kimis in forum Authoring (DVD)Replies: 0Last Post: 26th Dec 2010, 08:03 -
No preview in ImageMixer 3 SE Ver.6
By P.J in forum EditingReplies: 0Last Post: 5th Dec 2010, 10:16 -
what's BD-RE Ver 1.0/2.1/3.0??
By Ripperxx in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Aug 2010, 08:52 -
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
Installing a New ver of K-lite
By AndreL in forum Software PlayingReplies: 2Last Post: 23rd Aug 2007, 19:16
