im converting an AVI to VCD but the audio is too Low
i tried extracting the audio and saving it to WAV using virtualdub but i got the "no audio decompressor could be found" error
i used gspot and it said there that i already got 2 compatible codec one of them is AC3Filter
Fs=48000 Hz Bitrate=448 kb/s (5 ch) CBR <<< Gspot also gave me this info in the audio portion
what codec do i need or is there any way i could make my audio louder before or after i convert it to VCD format. im using Mainconcept in converting...
hacking the Net using typewriter :D
hi 8)
have u tried leaving the audio and video together and importing them as a whole into main concept, using layer 2 in the audio. another way is to use tmpg encoder this does a good job of converting using the wizard. hope this is some use
kb i did that but my converted VCD has a very low sound that's my problem that's why i opted to extract first the WAV...
hacking the Net using typewriter :D -
junkmalle after doing that do i convert my AVI to VCD using Mainconcept righ away? will Mainconcept automatically get the changes i made in AC3Filter?
will my VCD movie have a increase volume if i played using my VCD player? or is this change in AC3Filter master gain only applicable when i play the movie in my computer?hacking the Net using typewriter :D -
VCD only supports MPEG audio. So AC3 audio has to be converted to MPEG audio for VCD. Any program that uses the AC3Filter to uncompress the AC3 audio will get louder audio after you change that setting.
I don't know anything about MainConcept. If it uses the installed AC3Filter your audio should get louder. If MainConcept uses its own AC3 decoder that setting won't make any difference. -
thanks a lot guys...muchos gracias
converting movie to HD but low space format
By shahzadashraf30 in forum Video ConversionReplies: 7Last Post: 23rd Aug 2011, 05:32 -
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 07:02 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 12:44 -
low sound after burning to dvd
By ymurf in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 14:59 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
