Hello--
I have an MPEG 2 file of which I am trying to cut out commercials. I know how to use TMPGEnc to do this correctly, however I am having audio synch issues. Awhile back when I first found out how to use this program to Merge and Cut, I saw their were other programs that do the same thing. I am hoping to try one of those for better results, but now I can't find the original tutorial. Can somebody help me out with some recommendations? Thanks
I recommend getting VirtualDub Mpeg. Basicly it is VD with the ability to open MPEG files. Edit your video with that, then transcode it back to TMPEG Encoder.
This is the tutorial I was looking for earlier. Hopefully Womble Mpeg2VCR will work better!
http://www.digitalfaq.com/edit/mpeg2vcr/mpeg2vcr.htm -
And if that doesn't work, try VideoRedo next.
I can see reasons why that would work. Worth a shot.
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59
