i just installed Recordnow DX v4.61.
it's not displaying my dvd burner on the list of drives. it rocognizes my lite-on cd burner though.
i have nero, copytodvd, DVD X copy, and TMPGEnc dvd author installed. all of them recognize my dvd burner just not Recordnow DX.
i've been trying to burn this dvd i have and so far none of the programs listed above works for my standalone. it works on other dvds but not this one. i'm trying recordnow as a final recourse for this dvd. but it's not even recognizing my drive.
any ideas?
It wont list it cause its too old of a program and the nec 3500 came out after it.You might want to try different media,make sure your dvd player can handle the type of media you are burning and make sure you are burning compliant dvd files in dvd-video mode.
well it's not the media because i'm using the same verbatim dvd-rw everytime. it works on other dvds i've burned. just not these specific 2 dvds i'm trying to burn. however it works fine when playing on my pc.
This thread might help:
http://club.cdfreaks.com/showthread.php?t=102905
but you might want to upgrade to v7.2:
http://store.sonic.com/dr/v2/ec_dynamic.main?SP=1&PN=11&sid=39492&CID=178538 -
Originally Posted by MOVIEGEEK
The info in the CDFreaks link worked perfectly for me, just follow the instructions to the letter...install the PX 507 engine first then replace the other file. Don't upgrade to 7.2, anything from 6.0 up is not as good as the 4.5-4.6 versions. -
i followed the cdfreaks link
it says to install the pxengine 507 first but i don't see it in the thread
where do i download it?
thx -
Read further in the thread,i found it and followed all the instructions in the whole thread there and i can see my nec 3500 in recordnow 4.5 now.Thanks for the links MOVIEGEEK.
WMC Recognizing New Box
By Montani304 in forum Newbie / General discussionsReplies: 0Last Post: 13th Aug 2011, 20:48 -
recognizing MP4 vs MKV
By Leach in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2011, 07:37 -
W7 not recognizing camcorder.
By stanl in forum Capturing and VCRReplies: 1Last Post: 12th Dec 2010, 20:08 -
What makes a NEC3500 dvd burner stops reading burned cd's
By joy in forum ComputerReplies: 8Last Post: 1st Dec 2008, 16:19 -
All Drives Not Recognizing Discs
By Celcius in forum DVD & Blu-ray WritersReplies: 7Last Post: 31st Jul 2008, 15:33
