Hi, ive been using TMPGEnc DVD Author for a while now with good results, i have no problem with the software itself but, i use WINAVI to convert my AVI files to VOBS, then put them into TDA, usally 2 films at a time, and it then takes about 30 - 40mins for TDA to author the films,
I would presume the time length to be so if i inserted them as mpegs and the Authoring software had to convert them to vobs, but as they are alreay vobs why does this process take so long..
Hello,
Have you done any large fancy menus????
Also if you're doing MOTION MENUS that will add CONSIDERABLE time to your processing.
Hi, nope, no extra ordinary menu's , just plain n simple - no chapters just a jpg background.
Its not as tho my PC is slow
AMD 2500+ CPU
512 MB Ram
120 GB hard drive
GeForce MX5200 Graphics Card
I was just curious if this was the norm Authoring a DVD
Thanks JT -
I haven't actually tried the procedure you're describing, but I think if you just add VOB files to TDA, TDA has to convert them back to MPEG-2 before you can reauthor. So the authoring time will be at least as long as if you added MPEG files, and may even be longer since TDA has to convert the VOBs to MPEGs first.Originally Posted by JayTThat's my opinion, and if you don't like it, I'll change it.
Elementary streams will make the fastest author.
convertxtodvd to tda
By marioval in forum Authoring (DVD)Replies: 9Last Post: 18th Jan 2008, 06:14 -
TDA 1.6 menu help
By colt4523 in forum Authoring (DVD)Replies: 0Last Post: 3rd Nov 2007, 18:46 -
TDA 3 Quirk
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2007, 10:37 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
TDA 3 Questions
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 16th Aug 2007, 12:03
