  1. Is there any prog that I can use to rip and author a menu from a movie dvd and use it in a brand new dvd with another movie. I need that prog so that I could use the menu from the Lotr - Extend edition dvd in my brother's wedding dvd. Is there any prog that could help me achieve that?
  2. Member jeanl's Avatar
    Sep 2004
    CA, USA
    I've used PgcEdit to insert a menu into a pre-existing DVD, it wasn't completely straightforward though.
    Extracting the menu is usually fairly easy since it probably sits in one of your VTS_xx_0.VOB (or maybe in the VIDEO_TS.VOB). The trick is to import that in PgcEdit and then reconnect the button commands to do exactly what you want it to do.
    Here was my report on it...
    http://forum.doom9.org/showthread.php?s=&threadid=83389&highlight=menu+pgcedit+shrink
    Jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
