Hello guys
it's me again
Im still in ''reflextion time hehe''
What is happening why can't i get 1 DVD-r to be Great looking at least like on my pc......
I downloaded videos mainly avi's & Divx & i converted them with Cucusoft avi to mpg1 so it plays on my DVD player .... & i kept the same ratios & did the convertion then i used tmpgencDvdauthor & burn them......
Now on my screen it's now (more stretched than the original video....) & also i get pixeleration which wasn't hapening on my pc..... & it was perfect 16:9 on my pc & now it's stretched 16:9 .... what can i do to KEEP the SAME movie that is on my pc or that i download & to burn them to DVD-r & listen them on my tv with the same result as if i would be listening to it on my pc??
(exept getting a divx player i don't have any spare $ for it )
thanks guy!!
Hello,
When you say you used "keep aspect ratio" did you also use source video of 16:9??? If not it will probably stretch as you described.
If you were to use tmpgenc to convert avi to mpeg2 you need to select source aspect ratio 16:9 and "keep aspect ratio" to ensure the output will be unstretched widescreen.
do i have to put center keep aspect ratio or full screen? keep aspect ratio or full screen keep aspect ratio 2 or no margin THANKS
Hello,
99.99% of the time "keep aspect ratio" will suffice (I haven't run into a time when it hasn't).
You need to set "source aspect ratio" to 16:9. That's most likely where your problem is.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
DVD to DivX - Chapter Decoding Problem
By Nuin in forum DVD RippingReplies: 0Last Post: 25th Mar 2009, 18:56 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
RCA DVD player problem with DivX
By 4194 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 28th Aug 2007, 13:12 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 05:13
