why is the audioTS file always seem empty when either creating or ripping a dvd file, when i try to open an audio file in an application like ffmpggui it does not see any audio at all![]()
Results 1 to 9 of 9
And...........The audio TS folder is part of the original DVD specification and included to meet that spec. Never really implemented for audio. There are lots of DVDs that don't even include them. As Baldrick said, the audio is in the VOBs, muxed (mixed in) with the video.
Originally Posted by redwudz
The AUDIO_TS folder was implemented for audio, most specifically DVD AUDIO, a high resloution format far superior than dolby digital and dts.
DVD Audio is 24 bit / 192kHz in stereo and 24 bit / 96 kHz in 5.1 surround.
Only a few high end dvd players are capable of playing DVD Audio and on a pc, those with Soundblaster Audigy 2 series of sound card can take advantage of the format. -
I should have said 'mostly never really implemented'.
I've just never seen anything in it. Guess I've never ran into a DVD AUDIO file.
im using ffmeggui and when im trying to convert mp2 to ac3 so that i can use them on dvd authour but ffmpggui doesnt see any audio files when i point it to a video and audio ts file
Guess the reason thats its not popular is cos there aint many titles avaiable to buy and it is rather expensive.
It also implements several copy protections that is so far UNCRACKED and may probably remain so. it uses a 128 bit encyption, as well as CPRM Protection. No such software exists yet that can copy DVD Audio. -
Originally Posted by efiste2Want my help? Ask here! (not via PM!)
Reading through some DVD reference materials the other day and it finally dawned on me...
DVD players are meant to parse a disc in a particular order. It looks for these "Zones" or folders (in this order)
1. Audio Zone (AUDIO_TS)
2. Video Zone (VIDEO_TS)
3. Other Zone (JACKET_P, and anything else)
Therefore, even if the disc is standard DVD-Video only (meaning contains no DVD-Audio spec material), it makes sense to leave the AUDIO_TS folder in so that the player will follow the normal order of parsing (which for most players is to ignore the AUDIO_TS).
Also, this makes sense when you DO have DVD-Audio material, because the specs require the player to give 1st play priority to the Audio material OVER the Video material (there's that parsing order thing again).
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
