  1. Ok, I'm trying to convert an old VHS to DVD.
    I was using Pinnacle 8, but it keep making copies that skip frames, and had out of sync audio.
    So, I then tried TMPEG to convert the MPEG file to DVD (NTSC).
    It made a mv2 and a wav file. I tried TMPEG DVD Author, but all I seemed to be able to do, is make a iso with the two files.
    So, I tried to create a DVD from the iso in DVD Author, and it failed.
    Then I tried to do it again using Disc Juggler. It burned fine, but would only play in one of my DVD players (with *acceptable* framerates), but had NO audio!!
    Can someone explain to me exactly what to do here??
    Nov 2003
    I DON'T KNOW
    When you capture the vhs what file type did it make?
