Results 1 to 11 of 11
  1. Anyone have this same problem and know of a solution? I'm running XP SP1 and the taskbar never auto-hides despite having the option ticked in the taskbar options menu.
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Nope
  3. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I looked through the registry and didn't find a key that looks like it's the right one. Sorry Pac
  4. It's the smallest thing but it bugs the shit out of me.
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I've had that happen on my win98 machine, I had to uncheck auto hide then apply it, then recheck it and apply.
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Is 'Lock the taskbar' checked? That may make a difference.
    Nothing can stop me now, 'cause I don't care anymore.
  7. Makes no difference if its locked or unlocked, still won't go away.
  8. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Have you tried beating it?
  9. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Works for me. Im also running XP SP1. weird problem i guess.
  10. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Nah, it's probably mentally challenged and can't grasp the concept of hide and seek. :P Suggest you take it to a specialist.... Dr. Reformat. :P
    Maybe you have something running in the background preventing it from hiding.....such as mouseware???
  11. Well it has seemed to fix itself for now.
