I'm trying to make my first motion menu for a dvd (PAL), but I'm not sure what resolution I should make the images I import into Adobe Premiere...
Should I design the images with a resolution of 768x576 and then resize to 720x576 as I would when making a still menu or just import them to premiere in the original resolution?
thanks
Well, when i do motion menus, the main background is in motion..Therefore a size of 720x576 is a given...
But as far as buttons are concerned, i don't take too much time pondering over them, since they're getting resized down to, well..... buttons
So yes, go and import full sized pics, and you can't go wrong. I'll assume you know how to resize within Premiere...
Good luck!!!
Edited...Didn't notice you were in PAL land... -
Personally I resize all my images in my image editor. You have more flexibility and if you have a good editor it will have the 4:3 and 16:9 ratio crop box so you can crop them accordingly and your images won't become skewed.
Avchd ?'s - motion menus, shrinkers and more
By yoda313 in forum Authoring (Blu-ray)Replies: 12Last Post: 11th Jun 2010, 17:40 -
adding motion to still images
By fionawhitty in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2009, 05:08 -
Free Software for Motion Menus?
By thomasj in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2008, 14:03 -
Motion Menus in DLP
By ckurowsk in forum Authoring (DVD)Replies: 8Last Post: 8th Sep 2008, 08:23 -
Problem with DVDlab and 16:9 motion menus
By sektionschef in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 05:11
