dvd to dvd no prob , my question is this
recorded some stuff with mu under telly dvdr . amd i want to get rid of stuff recorded before the actual main file
my under telly dvdr records in ifo vob style format , is there a way to get rid of unwanted material without turning the thing into 1 avi or do i have to turn it into an avi , edit , re-encode and re-burn
what software would turn the ifo vob files into an avi if thats whats needed
cheers m8
but i have always found a reduction in quality with shrink , plus i dont want to shrink it anyway , also does ( coz its been along time since i messed with it ) it have a preview window that actualy lets you edit the file as is ?
in essence all i want to do is edit an existing dvdrw removing some unwanted tv stuff and re-burn to dvdr , hopefully without having to do all the ripping , re-encoding -re-authoring
is there not a file viewer that just lets u play or see the vob file in a preview window with the ability to cut the bits ya dont want and then just re-burn the wanted vobs and ifo -
If you've recorded this to a DVDRW, then DVDShrink won't be messing with the quality at all, because it won't be actually transcoding anything. Your DVDRW will be a DVD5, and you'll be burning to a DVD5, so it won't need to make any changes to the video and audio streams themselves in terms of quality. All we'll be doing is using it to cut out the bits from the VOBs, and update the IFOs for us in the same process.Originally Posted by gilbates
You could possibly try authoring software such as TMPGEnc DVD Author. It will allow you to import a titleset via the "Add DVD Video" button, and then you could use the chapter edit cut tab to chop out the bits you don't want, and it has a preview screen, and it won't modify the quality.Originally Posted by gilbatesIf in doubt, Google it. -
in my defence i have never needed to do this before so that was kinda new
everything is working and doing exactly what i wanted
thanks again m8
Difficult to explain (sorta) computer problem
By Heywould3 in forum ComputerReplies: 10Last Post: 9th Nov 2011, 11:48 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 21:47
