ok i converted my avi to m2v using TMPGenc and the audio using besweet. all converted fine. Then when i load them into tmpgenc dvd author it says the dvd files will be 3gb which is fair enough. it then takes about 4min (too short) to convert to DVD files and the outcome is only 500mb with half the movie missed of end. any ideas? Thanks in advance!
hmm not sure i know how to do that? i only know how to encode the audio seperate. you mean instead of selecting video only select video and audio? wouldnt that make the audio incompatible with dvd though
How big is that m2v file before you import it into TMPGEnc DVD Author?
Do you have enough free space on your hard drive?
Can you open the m2v and view it, making sure there are no glitches in it that might be causing TMPGEnc DVD Author to abort in the middle?
I'm not claiming to be an expert, your problem may be any of the above... or something completely different that I have thought of... -
the m2v file is 2.7gb and plays to the credits so i dunno whats up with it. will try it again and see what results i get.
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
ConvertXtoDVD vs. Tmpgenc DVD Author w/Divx Authoring
By Iron_Monkey in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 20:00 -
DVD authoring software like tmpgenc dvd author
By nic2k4 in forum MacReplies: 9Last Post: 29th Nov 2008, 01:34 -
Problem with TMPGEnc DVD Author 3 with DIVX Authoring
By LadyTaz in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2008, 20:36 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 19:53
