Firstly let me thank all those who helped a newbie like me figure out how to burn an entire movie onto one disc.....it is really handy and is working great. The only "problem" I have is the "look" of the finished project. The quality is good but the aspect seems to be a little off. I've been using the "4:3 525 line (NTSC, 704X480)" setting in the aspect ratio box and the movie quality is good but it seems like it's stretched or a little disproportional. Should I be using a different aspect ratio setting? ( I have little to no knowledge of these "ratios" ) Anybody else encounter the same "problem"? Thanks in advance all. note: I'm not sure if this helps but I don't have a 16X9 TV.....just a 'POS' 4:3 27" RCA.
Go to the left on this site and click on "What IS' DVD then click on "Video File Comparison" and "Video File Technical Information" to get up to speed on ratio's. Your ratio is in-correct, that is unless you want the dispropotional look.
I'm still not understanding from reading what you suggested.
Also.....maybe I should've noted how and what I'm using to make a "One disc VCD"...sorry. I'm using jim's guide located here: http://members.dodo.net.au/~jimmalenko/TMPGEnc1CD.htm
and using TMPGEnc to encode.
Anybody else know what aspect ratio I should be using? Thanks.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
my PCs can't detect disc format of VCD from Thailand
By Foobar in forum Software PlayingReplies: 2Last Post: 6th Jan 2011, 11:10 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 06:22 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 04:40
