Alright, on about 10 burns, nero has froze at like 99% or 100% ... and the dvds woln't play nor my audio cds... I have Nero 6.. is there a patch or something I should get? i just unistalled it and tryign it again, it only happens sometimes, and i'm away from the comp playing my ps2 gmae and it'll do it.. not like i'm multi tasking or something
Results 1 to 11 of 11
only_emo_kidGuest
Sounds like bad media. What are you using?
You might want to try downgrading to v5.5x. I used to have this problem which appeared quite suddenly. I had v6.x installed and it burned fine for months, then it had the problem you describe. After downgrading, every burn has worked perfectly well ever since. I've read about others having the same problem with version 6 - it appears to be quite unstable for some.Originally Posted by only_emo_kid
Brand means nothing. MEDIA ID, please.Originally Posted by only_emo_kid
www.nomorecoasters.comWant my help? Ask here! (not via PM!)
only_emo_kidGuest
probably so lol.. i'll get it in a few. I can't eject the cd from where nero froze until i restart, but i've got some downloads going that I'm afriad i woln't be able to connect back to the server if I restart... i'll get back with ya in a bit with those
Your problem sounds oddly familiar. If I am making a copy of a disk that I authored the same problem occurs. Only a reboot will free the disk. I use Ritek G04 and burn hundreds with no problem unless I try a disk to disk copy. A burn from the hard drive will work with no problems...ever!!Originally Posted by only_EM_kid
Sounds like simple IDE channel issues. Burner and reader CANNOT share a channel. Sometimes not even the same master controller.Originally Posted by goirish!!Want my help? Ask here! (not via PM!)
I have had this problem occur since upgrading to v 6.3.1.17. It happens randomly, It has happened while burning audio cd's and burning cd's from nero image files.
Media has been strictly HP cd-r 52X 80 min. / 700mb bought last week
IDE channel is not the reason for my situation as the drive is isolated
WTF do I do with a'*.wtv' file?
By olyteddy in forum Video ConversionReplies: 2Last Post: 24th Jul 2010, 10:18 -
WTF is with Ebay?!?!
By Noahtuck in forum Off topicReplies: 7Last Post: 29th Dec 2009, 19:33 -
From the WTF? Files
By Soopafresh in forum Off topicReplies: 7Last Post: 19th Apr 2009, 16:46 -
wtf is it?
By zoobie in forum Off topicReplies: 10Last Post: 25th Dec 2008, 17:03 -
Freezing during transcoding in Nero Vision 4
By TheGMan in forum Video ConversionReplies: 2Last Post: 21st May 2008, 11:09
