I used the Video CD feature of Easy CD creator to create a VCD. I follow the step using the Wizard. The .Dat file end up in the Sequance folder. The MPEGAV fold is empty.
The source .DAT file was copied from another VCD so it should be correct format.
What would I overlook?
Please help.
Thank.
did you convert the .dat to .mpg first and then added it to easy cd vcd creator? http://www.vcdhelp.com/convertdat.htm
Thank you for your advise.
It works.
What is the difference between .DAT & Mpeg file.
i just wanted to mention that VCDGear 2.0 does have some bugs so always be sure to check your mpeg before deleting your source. VCDGear GUI 0.02 doesnt seem to have the problem.
recently i was engaged in a very heated debate on another forum because someone used VCDGear 2.0 to convert ctp-hp2.bin to mpg and it droped the first few seconds of the video causing a gap between the 2 cd's. after some debate the culprit turned out to be VCDGear 2.0. the good folks over at vcdgear.com even aknowledge the problem here... http://www.vcdgear.com/faqQA.html#2.20
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
avseq01.dat file in mpegav directory
By ComputerScience in forum Newbie / General discussionsReplies: 8Last Post: 17th Jun 2011, 15:34 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
