Inaccessible_boot_device
I knew it was going to happen sooner or later... later I hoped.
Anyway my ? is this - Why am I BSOD'ing if I've altready gotten the splash screen? Isn't the NT loader file(s) being read at this point? Or is the drive itself crapping out during the process. BIOS sees the drive ok... I hear drive spin as well. Drive is a Maxtor 160/7200/8 about a year old
I have had issues with DOS errors (NTLDR not found, etc) in the recent past but luck had been on my side but now this...
Comments?????
Thanks,
makntraks
Results 1 to 10 of 10
In the theater of the mind...
It's always good to know where the exits are... -
Thanks....Originally Posted by bazooka
A man of many words...
I have my work cut out for me this weekend...
makntraksIn the theater of the mind...
You could possibly recover your files and burn them to a cd or dvd with a live-cd, its at least worth a shot. Slax live-cd is available here:Inaccessible_boot_device
www.slax.org
and Knoppix is available here:
www.knoppix.net
After you burn your files off (if you can) you could either reinstall onto that hd or buy a new one. Its at least worth a try to see if you can recover your files though. -
is your boot.ini in the right place?
Did you try a repair? -
Any other error besides that? with W2kSP3 I was having some anamolies with BSOD on boot and it turned out to be corrupt hardware profiles.
(Had to boot to DOS via 2k boot floppies, run diag, (drops you to DOS) and find the files associated with hrdware profiles and swap a few around (always have at least two) -
Hey- thanks for the replies!
I've decided to wipe it all and start from scratch. I figure I'll be losing nothing but time and in the end have a fresh system.
Again thanks,
Excuse the bump....Originally Posted by makntraks
Success! Although I figure my drive only has a few "lives" left, I took the drive out and installed it in another PC. It ran through the Checkdisk process and VIOLA - drive is back up and running...
Could be a tip for those that might find themselves in the same situation
Again thanks and maybe my little experiment might work for others...In the theater of the mind...
I don't know why I didn't mention this before, but did you ever boot from your install CD and try chkdsk in the recovery console?
Nothing can stop me now, 'cause I don't care anymore. -
I thought about it but figured it was beyond hope.... My trying it in another PC was just because I had 2 pc's apart...Originally Posted by ViRaL1
Thanks though, I appreciate all the suggestions...
Blue Screen of Death (BSOD)
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Dec 2009, 05:31 -
ffmpegX splash screen still showing after registration
By Le Main Event in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2009, 11:11 -
Trying to create a splash screen for my dvd?
By wan2no in forum Newbie / General discussionsReplies: 16Last Post: 4th Dec 2008, 22:11 -
How to add a splash screen at beginning of avi
By Overfloating in forum EditingReplies: 3Last Post: 20th Jan 2008, 04:37 -
Background/ Splash screen patch in the UK
By stavdav in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 11:13
