this is old but the first time ive seen it.. anyone ever seen before?
this is a robitic saw cutting through a pipe in 6000 feet of water. the presure in the pipe is 0psi and hte water presure outside is 1.2 tons per square inch. then this crab comes along.. keep in mind that this hole is only 3mm wide..
Crab meets pipe
Water pressure:1
Crab: 0 -
What I find even more amazing is the fact that a crab can survive 1.2 tons psi in the first place.
No, I'm from Iowa. I only work in outer space. -
It should do just fine as long as it has no gas pockets. Water has a hard time collapsing in on itself.
After the first suck towards the pipe, it looks like all the guts and everything were instantly sucked out of the shell. The only thing left was the exoskeleton. DO you think it felt anything?
As long as the pressure is equal inside and outside they're OK. Immediately move them from that depth to sea level and they'd explodeOriginally Posted by babyboo
Audacity With FFmpeg Plugin Is Amazing
By Soopafresh in forum AudioReplies: 6Last Post: 17th Jan 2010, 18:25 -
How Do I Keep The Amazing Quality When Converting PlayTV .M2TS Files?
By ltd. in forum DVB / IPTVReplies: 4Last Post: 18th Nov 2009, 04:53 -
Some amazing landing
By Webster in forum Off topicReplies: 0Last Post: 8th Aug 2009, 14:03 -
damn Subtitles can't be burned ?!
By insext in forum ffmpegX general discussionReplies: 19Last Post: 13th Dec 2008, 05:49 -
WOW! AMAZING video. How can I create like this?
By yunakokimama in forum EditingReplies: 8Last Post: 29th Apr 2008, 05:58
