After downloading all these codecs and installing them, where should I put them, is there a folder like in windows that all the stuff should go ?
If you have installed them, then they should now be where they need to be. Copy the installer files to CD in case you ever need to reinstall windows.
Be carefull installing codecs willy-nilly (I think that's first time I have ever typed that), as some of them can clash and cause problems. Best to install only the ones you absolutely need, and do it one at a time.Read my blog here.
Question about codec's
By carl606 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Apr 2010, 09:54 -
Sopcast/codec question
By Bully9 in forum Video Streaming DownloadingReplies: 0Last Post: 25th Jul 2008, 14:31 -
Codec question
By cowboysroy31 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 17:33 -
Question about Lagarith codec
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2007, 22:59 -
quicktime codec question
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 06:29
