Hi every1. I just got this recorder to transfer my old 8mm tapes of family movies. First of all. Any1 know if this is a good recorder?
Second, here is what I plan to do: I plan to just burn all the cassets to DVD without organizing them.
i then plan to go to my computer and that is where I want to cut out stuff from one file, add it to another, move things around, add some effects, menus, etc.... Can any1 help me out with this part? Is this even possible once the DVD is burned? If yes can you point to the best program for this sorta stuff. Thanks guys.
you'll want to record to DVD-RW or DVD+RW and re-use the disks
copy the files to your hard disk on your PC
remember that the video files will eat up your hard drive space fast
so, you'll want to do some planning
2 hours of video will take up almost 5GB
pull the files into a DVD authoring program and re-author
I personally don't go very fancy with my DVD menus, so I use TMPGEnc DVD Author -
thanks broadway I know that much though. I have DVD Author but it only lets you cut the file, plus I keep having these errors with it. But it doesnt let me cut a specified time, and then make it into a seperate file on another dvd or join it a different place. Plus I cant put in any effects into the videos. Its a very basic program that u can use for cutting out commercials, but not for what I want to do. Can any1 help me out. I am really lost. Do I need some sort of program to convert the vobs to mpegs?
If you plan to edit these file's you should not convert them to Mpeg2, much harder to edit and you will lose more quality.
Originally Posted by zgrm100
if you are looking for a more sophisticated editor, try the www.womble.com; others on this forum use their programs to edit MPEG2
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 19:53 -
Sony dvd recorder model RDR-GX300 cannot play/record discs
By hdubya in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 02:40 -
Can't transfer 8mm tapes to DVD-RW, advice please
By nathanaa in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2008, 13:18 -
Sony RDR-GX300 DVD Recorder can't record channels 200+?
By showmi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Jul 2008, 14:49 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 21:28
