I've been looking for a program to edit the VOB files from my DVD recorder. So far the only program I've found that does what I want is TMPGenc Xpress 3. This has ' select source' mode which takes all the files from my Philips DVD recorder and encodes them to MPEG2, which is what I want. The trouble is, they say the full version requires online activation, and my editing machine does not have a net connection. Are there any other versions of TMPenc which don't require activation? Thanks
Results 1 to 30 of 30
no
it's call a crack activation....hehehhehe
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator BJ_M
do not advocate warez
The older version of TMPGENC, known as TMPGENC PLUS 2.5.x are all activation-free (at least they were in the past, not 100% positive these days). I use this. Or you can buy somebody else's encoders, like Procoder, Mainconcept, CCE.
Then demux with TMPGENC in MPEG tools to M2V and audio, then remux only those portions (strip non a/v info, reason you cannot just rename files).Originally Posted by falberniWant my help? Ask here! (not via PM!)
2.5 will except vobs .. ussually , not always ..
It accepts vob, but not the audio. At least for the vob I tried. It would encode the video.
Too late. A terminator has been dispatched to your location. You will not last the night. By the way, after he scores and whacks your butt, may I have your watch? It looks really nice, and you won't be needing it any more...Originally Posted by vitamineHello.
Amazing. I don't think I ever so many "off with his head" before in my life. Anyway, if your trial version of TMPGenc expires, you can still load MPEG-2s and MPEG-1s in it, but you cannot save to MPEG-2s. The plugin is called:Originally Posted by winifreid
TMPGEnc_MPEG2_Plugin, (what are the odds of that happening?), and is available in the Tools section at left.
By changing the VOB extension to .mpg, most VOBs can be loaded, but is not a given.
You gurus should be ashamed of yourselves.Hello. -
Is telephone activation not possible.
I know that some software that require activations allow activations over the phone for those without a net connection. -
i dont think so - requires a net connectionOriginally Posted by waheed"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Pull! Bang! Darn!
Pegasys people, the authors of TMPGEnc, are funny. TMPGEnc started as a freeware, the started charging money only because the were forced to pay royalties to MPG2 organization -- ended up with most severe online validation. Nowadays TMPGEnc plus is not sold anymore, they have only the freeware version available, where MPG2 encoding expires after a time limit. They wanting to keep cash flow to continue exist as a company is understood, what I fail to understand is why the stopped selling TMPGEnc 2.5 plus.
It looks like TMPGEnc 2.5 Plus is still available for $37.
http://www.pegasys-inc.com/en/product/tp.html -
That's right, only you don't see it on their home page: http://www.pegasys-inc.com/en/index.html
After doing a little Google searching around, I found a link below that might help
you.
You can download a TMPGenc version v2.521.58.169 here:
Though, its from Pegasiss, ( the ones that R charging
) the webpage says
it's Freeware but I can't garentee the MPEG-2 though it doens't say
trial-ware or anything
* http://216.239.37.104/translate_c?hl=en&u=http://www.pc-facile.com/TMPGEnc_freeware_s1...26as_qdr%3Dall
Please try and see if that works out ok for you w/ mpeg-2 support or not. I don't know
-vhelp -
Freeware versions can be downloaded from Pegasys website as well. Freeware versions, wherever they are downloaded from, MPG2 encoding is time limited.
ok. I wasn't totally sure about the MPEG-2 stipulations
I saw it say freeware, and thougth this might be a *limited* version.
-vhelp -
on the note of dvd2avi ...
My experience with this app was like this. As long as you *did not*
choose the Force Film option, you would always have a perfect
source to IVTC (as long as you knew w/out a *shadow* of a doubt, that
it was infact true Film throughout) process. Anyways.
My version of TMPG ( v2.520 ) opens VOB files w/out any problems. I use the
MEPG-Tools area to de-mux the video/audio into *.m2v and *.Mp2 file for (and
is the best approach for re-compressing)
But, if you don't have space, then the dvd2avi is the best alternative, and
I too have never had a problem (though I continue to recommend you use it
w/out the Force Film feature)
-vhelp -
No. You're thinking about "free software", not "freeware".Originally Posted by lpn1160Want my help? Ask here! (not via PM!)
Thank You LordSmurf, I stand corrected !!
"The software said Win XP or better, so I Installed Linux"
activation does not stick
By anilty in forum ffmpegX general discussionReplies: 4Last Post: 5th Apr 2009, 07:52 -
Registration key and activation
By philparis in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2009, 17:56 -
Lost my activation code
By friday131 in forum ffmpegX general discussionReplies: 1Last Post: 22nd Jan 2009, 23:16 -
Win XP activation code
By CSULB71 in forum ComputerReplies: 19Last Post: 18th Apr 2008, 19:49 -
Lost Activation Key
By scully_uk_98 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Feb 2008, 11:53
