Try checking console and system logs for clues. The Console utility [usually in /Applications/Utilities] is one way of viewing them.Originally Posted by DVmadman
Results 31 to 35 of 35
I figured out the problem why some of my apps wouldn't launch. Applications visible in finder are actually special directories. If you control-click on any app you will see an option for "show package contents". If you select this you see the components of the application in subdirectories.
Using my knowledge of unix, I fired up the terminal program and looked at the subdirectories under the applications that do not launch. I found that the directory and file permissions did not match the apps that do launch. So I changed the permissions to match and now all my apps launch and function just fine.
In retrospect maybe doing a "repair permissions" from disk utility would have fixed this. I'll try that the next time I encounter this problem.[/quote] -
Glad you resolved it.
Repairing disk permissions won't touch any third party software, only affects OX files. -
(and useful info which I intend to remember), but I thought you re-downloaded the problem app - I don't understand why that didn't solve this problem.
And, no offence, just a friendly suggestion - you also might want to avoid the phrase "using my knowledge of unix"- that sounded terrible :P
Trouble capturing from VCR, completely stumped
By mikeveli20 in forum Capturing and VCRReplies: 12Last Post: 25th Oct 2009, 10:00 -
DivX -> AVI/MPEG - stumped!
By ouroboros10 in forum Video ConversionReplies: 4Last Post: 7th Apr 2009, 13:23 -
VHS to DVD to PC has me stumped! Cant import audio to my software...
By jojokaa in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2009, 09:58
