    Feb 2003
    USA Heart of Dixie
    I've seen a "how to" in the forum several times before, but cant seem to find it now. Using DVDShrink to rip, and DVDDecrypter to write to dvd-r.
    Personally, I use Nero with dvdshrink with no problems. But, I was just currious as to how this was done.
    Coffee makes you happy.....Except when it messes you up
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You need to do it in iso mode. Dvd decrypter can write and burn in iso mode
    I forgot how to shrink to iso in dvd shrink. Though you could always use a freeware program to turn the shrunk video_ts folder into a iso and load that into dvd decrypter
    Kevin
    Jun 2004
    USA
    I open the video_ts folder with DVDShrink. Then when you choose 'Backup' there will be an option in the first tab that has a pull down
    menu. If you have DVD Decrypter installed on your system then the option will be there to burn the DVD using DVD Decrypter.
    I have done it both ways and I think burning with DVD Decrypter yields a better result but I would be hard pressed to verbalize just why I think it is better.
    wwjd
  4. Member steptoe's Avatar
    Click this link to my method that I use. It can also do DL burns, just change the settings, its all explained in the guide with plenty of screenshots to explain whats going on
    http://www.thescrapyard.pwp.blueyonder.co.uk/files/video/using%20freeware%20utilities%...r%20movies.htm
