The problem I am having is a washing out of the colors on my VHS captures. The caputre's I do are perfect 1:1 ratio, But the problem is that the video is washed out with white colors so it looks to bright. I have tried to adjust the contrast and brightness of the capture programs but to no sucess. I turned around and hooked up my DVD player through the RCA Video-In and also Tried the S-Video in. The Picture is not washed out at all. It looked perfect! I tried another VCR and same thing with the first one, washed out. Is it because a VCR is such low Resolution that it causes this? Should I get a High Resolution VCR that has S-Video out? Or Is there something Else that should fix it? My DVD player worked great on it, but 2 VCR's that only have RCA look washed out.
I have a:
1.4GHz Athlon
Asus V8200 Deluxe
2x60GB HDD
El-Chep-o Toshiba VCR
I use:
InterVideo WinCoder
ASUS Digital VCR
Also I have used almost every video card and video capture drivers I could get my hands on, and same thing:
DVD - Great
VCR - Bad
I am also using Windows XP Pro -
I have the same problem, brightness to high using Windows XP.
I tried with VitualDub, ASUS Digital VCR,iuvcr, WDM 1.04,WDM 1.05, WDM 1.06 and now with WDM1.08.
I am using a NVIDIA Geforce3 Asus V8200 Deluxe and NTSC VCR.
Any help would be great.
i have this whiteness problem too after i upgraded to win xp. is it the drivers, tv tuner or win xp??
Avermedia TV98, Voodoo 3 3k.
i think alot of people want this problem resolved! i've looked for patches..no luck -
Have you tried calibrating it to your source footage with a histogram? There is one built into Virtualdub.
I found that I couldn't adjust the settings in virtualdub directly, but setting them in AMCap saved them for the VFW apps as well. I think it's a WDM driver thing.
Also, on my WinTV board I have to set my input to either Svideo or Composite, depending on the line I'm actually using to feed in the signal. If I pick the wrong one the colors are messed up similar to what you are describing.
Correcting saturation, contrast, brightness, etc...
By takearushfan in forum RestorationReplies: 28Last Post: 21st Sep 2011, 23:32 -
Need Editor for Contrast, Brightness, Color Saturation
By HorseTears in forum EditingReplies: 1Last Post: 15th Dec 2009, 11:32 -
Video editing of brightness and contrast?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 6th Feb 2008, 19:31 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 23:26 -
Fixing brightness/contrast on a DVD
By Salva Veritate in forum EditingReplies: 4Last Post: 7th Oct 2007, 21:05
