Im having problems with a Vob converted to an Avi in virtualdub
is not recognized in Premiere Pro it just hangs while inporting.
I have loaded the mainconcept codec to allow an Vob to be imported,
though there is no audio with the video........i imagine i could grab the
audio with other programs.
I really like the Virtualdub program ,is there a reason why Virtualdub
vobs converted to an avi is not recognized by Pro......and is there
a work around? ......Im just trying to mix dvd video with my dv camera
video from and edit in Premiere.
THanks in advance
Makkon
what codec did u use when converting the vob to avi?
The distance between genius and insanity is measured only by success... -
I think i went thru them all .........i spent quite a bit of time experimenting
with them , and windows mediaplayer will play the converted Avis
so it sounds like adobe is not liking something from VDub.
Also i had used 1click Dvd2avi programs and Premiere accepted
them , but i like the quality of Vdub much better.
I was following a tutorial on just pulling out chapters and
vdub is one of the suggested apps
This is a work in progress
Thanks in advance
Makkon -
Alright i figured it out by reading other posts,,,,,,
I converted without audio....Ac3 and was able to import
into premiere.
reading another post stated some apps like Premiere does
not know what to do with the Ac3.
Ill pull out audio as a wav and edit in premiere.
Makkon
Tuning MOV -> AVIsynth -> Virtualdub -> Premiere
By dirtdad in forum EditingReplies: 11Last Post: 18th Dec 2012, 11:13 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
HD Video from VirtualDub to Premiere Pro for editing - What codec is best?
By gliebetronics in forum Video ConversionReplies: 6Last Post: 14th Jul 2008, 12:57 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
