Hello,
I'm using XP SP1. I bought a Hercules Smart TV (mono) with PowerVCRII.
My problem is that I cannot finetune channels. Therefore some channels do not appear, or only in black and white.
When I use another application (dscaler or K!TV), I can offset the channel frequency (+/- 0,25 MHZ) and then there's no problem. So essentially there's nothing wrong with my hardware, neither the cable length or quality is an issue.
My question: Can I finetune in PowerVCR, cause I want to use the hardware MPEG-2 encoder on the Smart TV card. Maybe a some registry-editing is needed
Or, alternatively, do you know a free program I can download and use with the Smart TV card.
I've tried without succes:
-alternative WDM drivers
-updating DirectX and applying non-NTSC patch
-all patched/updates from Hercules.com (maker of Card)
-posting my problem with Cyberlink (maker of PowerVCR). No luck. They said some things about signal strength, cable lenth etc. But as I stated, dscaler and k!tv work in the same setup without problem
-using Hauppauge WinPCR
-using Chris TV
-using C!TV
-changing PCI slot
etc
Be advised that I'm from the Netherlands, where PAL B and Pal G are used. Most "problem" channels appear to be in the PAL G range. For info on channels: see http://www.multikabel.nl/freqs.php?gem_id=33&check=check
Please note that I'm not looking for a solution involving AVI capturing (or something like that) and then conversing AVI to MPEG-2.
Any ideas/suggestions. It would make my day...
Results 1 to 12 of 12
Very interesting but you haven't tried Intervideo DVR software.
WinDVR 3
or
Win DVD Recorder Platinum 5
I use both but mostly have the Win DVD Recorder software on always. If you can use Dscaler then you can use Intervideo products. Try it. I've tried PowerVCR II didn't get good results. Dscaler is okay but you know you can't record with it so good. If you find that Intervideo software doesn't work for you try Mainconcept PVR software.
Good luck! -
tipstir,
thx for the suggestion. I will try, but I'm pessemistic. From the intervideo website I gather they are using wdmfiles, just as many other PVRs.
Also: I've only got limited OEM versions of these programs. Already tried these, no luck. Maybe more luck with full versions 8)
Martin -
WinDVR (Intervideo products, period) = forced blended deinterlace
PowerVCR II = software only encoder.
If you want to use the hardware, use the software that came with the hardware.Want my help? Ask here! (not via PM!)
Well if you don't want to try WinDVR 3, there is Mainconcept PVR. I don't care for PowerVCR II nor Chris TV Pro. Intervideo I know there a lot of these PVR forget the Home Theater 2 awful program. WinDVD Recorder Platinum 5 is better than WinDVR 3 in picture quality and features and also has AC3 enable. Anyway since getting the new capture card I dumping all of those and staying with the GB-PVR for now to use with my Media MVP 1000.
Best Regards,
Tipstir
MediaMVP Supporter -
Need a POWERFUL PC for MainConcept.
Mainconcept will run on PIII 900 MHz with 512MB of RAM, I know I've tried it.
PIII, P4 or anything higher with the right tweaks will improve performance. I never have any problems with Encoder from Mainconcept current version I am using is 1.04.02.Best Regards,
Tipstir
We're not talking the same thing. I'm talking about CAPTURING video with MC 1.4. Your version does not capture, only encode, and your PC if nowhere near powerful enough. My PC is barely powerful enough.
Oh okay capturing it gotcha!
I do have a HTPC P4 2.61GHz, 1GB of DDR RAM should be enough right! To capture with MC. But you can capture with ULEAD DVD Workshop and encode the video also.
Btw the PIII 900 MHz I just use that with MC 1.4.2 to just convert PAL VCD to NTSC MPEG2 takes less than 30mins to do 286MB file even for re-encode the picture comes out very good as the original.Best Regards,
Tipstir
Yes, that P4 should have the needed juice.
Smart TV Tuner card and ps2
By neko_chan in forum Media Center PC / MediaCentersReplies: 3Last Post: 27th Apr 2009, 03:09 -
Get Smart backup
By Shermanbay in forum DVD RippingReplies: 26Last Post: 11th Nov 2008, 23:54 -
GET SMART no copy
By shoesss in forum DVD RippingReplies: 3Last Post: 7th Nov 2008, 09:48 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 04:30 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
