  1. hi
    when watching half the film on w m player the film is ok in wide screen, when joining the two film clips together in tmpg merge and cut after joining them together it also re-writes the headers and the film is much smaller on t.v. in wide screen in height. what does the header do and is there a way of setting this in tmpg, to correct this ? the version is tmpg 2.59 plus.
    many thanks
    Are BOTH files identical in spec? Does not sound so!
  3. hi
    got rid of the original clip but still got the joined clip in tmpg after joining with tmpg authorised with dvd-lab the clips i have are svcd mpeg 2 and converted to dvd. I just wondered about tmpg re-writing the headers what this did exactly?
    many thanks
