  1. Hi, guys,
    Well, my TV capture card is finally working and I´ve started salvaging my old VHS tapes.
    However, when I try to edit tham in VirtualDub (I´m not very friend of Power director), the only option is to save it as an AVI, which of course occupies LOADS of disk space.
    Is there a possibility to save my mpeg2 captured media files as mpeg2 with Virtualdub?
    Help...
    "They say that if you play the Windows CD backward you can hear satanic speech; well, that´s nothing.
    When you play it forward, it installs windows."
    Mar 2003
    Uranus
    nope
  3. Hi,
    To do simple cutting/trimming of mpeg files use MPEG2VCR. Very good and fast.
    Enjoy!
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    yep, it's possible.....you have to use YMPEG as codec with it though. Bear with me while I gather some more info ...
    If in doubt, Google it.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Found it !
    https://www.videohelp.com/forum/viewtopic.php?p=1110298#1110298
    Two birds with the one stone there:
    1. Buy YMPEG, configure it as your codec and it saves in MPEG2
    OR ...
    2. Frameserve to your favorite encoder.
  6. I have not tested YMPEG, so maybe that is good, but there is certainly no reason to save your file to AVI with V-dub. Just frameserve your edited footage out to your conversion tool and save a butt-load of HD space.
    "Rarely is the question asked: Is our children learning?"
    George W Bush - Moron
