hey all.. im a newbie.. I'm looking for another program that encodes faster than tmpgenc. It takes 2 hours to encode a 4 minute video to mpeg 2 720x576. There's got to be a better way! no?
2 hours? There is something wrong, that shouldnt take more then 5 mins, I would think.
At worst it should take you about 4X runtime with TMPGEnc - so in your case, about 16 minutes...
... Unless you are using filters. You've only got an 800MHz CPU I see but it still [i]shouldn't[/b] take 2 hours for 4 minutes, unless you're placing some serious load on your PC while it encodes. You might want to try some of the speed enhancement tips I've listed in this post.
Also, CCE is quicker than TMPGEnc FWIW.If in doubt, Google it. -
Mainconcept is also quicker, however we are talking degrees. I agree that your times are way out of whack, and you must have some serious issues elsewhere to cause this. What was your source specs ? If tempgenc is also doing resizes and other filters then things will take much longer.
Ultimately, the only way to substantially increase your encoding speed is to upgrade your CPU, get lots of memory, encode from disk to disk (i.e. source on disk a, target on disk b) and use good quality source that does not require filtering during the encoding process.Read my blog here.
im in the process of building a new pc.. so that will chop off some time.. Right now it's taking 22minutes.. (because i didnt use the template that I downloaded from the following site.
I used the pal 4:3 template (towards the bottom) http://www.videoproductions.com.au/html/mpeg2.html -
CCE only accepts avi or quicktime? All of my files are in Mpeg format.
In that case you need to learn about frameserving. There are guides for thsi.Originally Posted by xxxjojoxxx
Encoding for faster streaming and MP4Box ?
By Miata in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2010, 20:57 -
Is encoding ur file unto another HDD faster?
By jones24 in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2009, 18:45 -
How do I get faster encoding time from quad-core processor?
By nick101181 in forum Newbie / General discussionsReplies: 5Last Post: 26th Oct 2008, 15:54 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
Increasing Encoding Speed?? What Hardware makes it run faster?
By sandman423 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2008, 23:09
