Just some quick questions, i wanna back up some mp3's, wmv, mpegs, and programs etc. to dvd.
Just wondering in Nero what format should i choose? UDF, ISO
And do i need to archive the files with winrar first or can i just add them to the dvd how they are?
Thanks/
Results 1 to 15 of 15
Hello,
I use roxio 6 creator classic. It has a data mode for dvd available. I assume your Nero version has something simialar. UDF is probably ideal. But look for a plain data mode.
You can burn files to DVD just like you would to CD. You just have more space. Not to contradict, but why would UDF be better than ISO? I thought some systems need extra drivers loaded to read UDF, but for ISO all you need is a DVD capable drive. Although there are probably other advantages that I'm not thinking of atm.
Nothing can stop me now, 'cause I don't care anymore. -
Hello,
Viral1 - sorry don't really know. I just use data mode in roxio. I'm not sure.
I just use nero express and select data dvd.
I hate to choose between all the options in nero. -
nero also has a "backup" function.. all you do is start it and select the files.. it will verify then index then set to backup.. it will even span across DVDs if needed.. it will then verify all data to make sure its a 1:1 copy.. no need to arange into 4.3 gig sizes to fill disk does it for ya..
I should try that backup option, for my raw DV tapes.
Personally though, so far, whenever I've backed things up I just hit up the nero wizard, burn a data disc, and bob's your uncle. UDF/ISO I have no freaking clue; whatever nero said to use. The benefit of this is that it's simply like an unreadable folder in windows explorer, and entirely 100% accessible in the future. -
Nero uses ISO by default if I recall correctly. Most people shouldn't have a problem using ISO because it works on PC and Mac
Originally Posted by Skoorb
what i wanna know is how did you know he was my uncle? was it because we look alike :P -
I use ISO for data DVD\CD\HD-Burn discs and have never had any problems with that.
Cool thanks for the info, i thought i may be iso, but wasn't sure, all i have ever done is burn Dvd movies.
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 08:17 -
Backing Up media files
By AndreL in forum MediaReplies: 1Last Post: 11th May 2011, 03:54 -
Backing up files
By Deathstrike in forum ComputerReplies: 4Last Post: 5th Jul 2010, 21:16 -
Question about backing up a dual-layer dvd (files vs ISO)
By bgart13 in forum DVD RippingReplies: 7Last Post: 19th Aug 2008, 00:16 -
Backing up Divx files
By didikai in forum Newbie / General discussionsReplies: 4Last Post: 19th Aug 2007, 13:32
