alright, here is my problem, i have the Studio PCTV Pro(Pinnacle) and i did have some trouble gettting it installedat first then i had it working fine, could not capute in uncompressed avi, and thats fine, looked great with picvideo but had no $$$ to reg. it. anyway, i had a system crash and was able to get everything running fine but i could not get the card to work so i did a fresh install of windows. not the card can pick up stations of the cable, but it only pics up some when before it picked them all up crystal clear, and in the picture there are vertical lines that were never there before. can some one please help me, i'd start to like capturing again or should i forget the internal tuner and just use the composite or s-video in jacks? thanks in advance.
System:
1ghz tbird
384mb pc-133
30 gig ATA100 7200rpm(main drive)
30 gig ATA100 7200rpm(capture drive)
Geforce2 Ultra
Studio PCTV Pro
TBSC Sound card
hell, if your card has s-video then i'd use it. i am stuck with composite.....
the problem is my POS tv doesnt have an s-video out, is there sum kind of converter i can buy, and is composite that bad?
I was looking for a way to use an s-vido cable as well.
I have a scart plug that individually takes in the audio and video cables seperatly.
I want to capture from sky (digital). So could I plug the scart socket with just the video cable plugged into it and use it like that?
Thanks -
actually composite is pretty good. much better than straight cable. i don't know about a converter for s-video. i think there is a converter such as a standard rca plug on one end and a s-video plug on the other. but i've been told it would be the same quality as a staight rca cable......
well since the controllers and boards r sending out the signal through the RCA outs, yes, upping to S-Video would be pointless.
Simalrly, downmixing fromm S-Video to RCA is stupid because u loose the extra quality -
so compostie will be fine, or even better tehn the regular cable? now all i need is a long enough cord, lol. thanx guys
vhs with vertical lines
By spiritgumm in forum Video ConversionReplies: 29Last Post: 22nd Aug 2019, 10:17 -
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 22:46 -
Vertical Lines from Video Camera
By solarblast in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2008, 22:30 -
Vertical Lines Appearing On Capture
By XBucklawX in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2007, 12:11 -
vertical lines in 2.5
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 23rd Jun 2007, 15:53
