I want to be able to directly copy DVD+Rs with my Dell XPS, and am wondering if I can pull out the Samsung SW-252S CD drive that came with the PC, and substitute a NEC ND-3500A, given that a NEC ND-3100AD in installed in the second bay.
I've seen that both NECs can't be configured as writers, but I just want to be able to read +Rs and +RWs from one drive and copy them without first sending them to my HD. It may prove helpful to have -R/-RW direct copy capability as well.
What are the "gotchas" with such a set up? Should both be jumped as CS?
I am currently running 2 dvd writers (nec nd3500ad and a sony dru-530a) in my pc and I just configured the jumpers the same way the old drives were set. Both are running smoothly with no problems and I'm able to use either as a writer.
I am Jack's medulla oblongata -
doxtr111 and B2D327, thanks for your replies.
Can you tell me if both DVD writers are running on the same IDE channel?
Also,I don't know if I need to be concerned about contention with my hard drives, which are dual 250BG Serial ATA Raid 1.
Dell XPS 420 memory problem
By Prot in forum ComputerReplies: 11Last Post: 20th Apr 2011, 11:14 -
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 11:24 -
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 14:23 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 20:39 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
