I compiled 54minutes of video footage into a mpeg2 file. When I play the mpeg file on my computer the audio/video alignment was perfect but after I convert it to DVD format using DVDlab the audio and video aren't in sync with eachother for the last half of the movie. (tested on my hard drive and on a DVD player)
Any advice would be great. I did some research and found a lot of good comments about DVDlab so I hope this is something easily fixed.
-Thanks
Andy
What version of DVD Lab are you using ? Some of the Pro betas had this problem (amongst other things)
Are you working with elementary streams ? (i.e. audio and video seperate) or a combined mpeg ?
If it is a combined mpeg, DVD Lab will have prompted you with an option to demux. If so, so you demux, or choose not to. The recommendation, when prompted by this dialogue, it to demux.
Otherwise, check out the mediachance forums here http://www.mmbforums.com/ to see if there is an answer.Read my blog here.
You can try using the Alternative muxer during the compilation stage instead of the main one. The one time that I had A/V sync issues with DVD Lab (source files were fine, however the output from DVD Lab had A/V sync issues) I tried the alternative muxer and it solved the problem. It's worth a shot.
No, I'm from Iowa. I only work in outer space. -
Originally Posted by guns1inger
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Encore CS4 screws up chapter selection on custom menu (video demo inside)
By aple in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2011, 09:53 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 12:30
