could someone please help me or give me some advice what i might be doing wrong or overlooking i cant seem to get any dvds to play on my stand alone dvd player after converting avi files to dvd . i keep getting "this disk is not compatible" im using dvd-r disks and tried converting using "winavi converter" and "Xilisoft video converter" same problem. i can get it to play on one of my players,it plays all formats! my stand alone is a "Panasonic DVD recorder #DMR-E55 in the book it says it says "play only disks" DVD-audio(dvd-a),DVD-Video(dvd-v),video cd(vcd),audio cd(cd)can someone please tell me what i might be overlooking or not understanding? or even what i might try? thank you
Results 1 to 16 of 16
your better off using good branded media,instead of some princo or other crap brand,.sounds like cheap crap media,but you could always try copying with +r discs.
that or use another programme,instead of those "shady" ones.
rip the film with dvd decypter,then compress to dvd+r with dvd2one,then burn with nero or copytodvd,persay,
if its a backup already,then try to use dvddecrypter with iso read,iso write.
dvddecrypter - MODE-ISO read,iso write is where it is. -
yes i can play it on my older dvd player Brand: XWave.
i used the default burner thats incorporated into winavi decoder
its a video cd avi (video clip) theres 2 parts
hope i answered that right, and thanks for responding to my post whether or not you can help me- its much appreciated. -
sorry i forgot . i also tried burning with "roxio easy cd & dvd creator"
and like i said it blays fine on my xwave dvd player, but it wont play on my panasonic stand alone , hitachi stand alone or a sylvania tv/with built in dvd player -
sorry, im not sure what you mean. if your talking about my dvd burner,its a "Dual" dvd-+/R/RW
No, the disc. What manufacture? What kind? +R? -R? +RW? -RW?
/Mats -
...and manufacture? Tried some different kinds?
/Mats -
memorex 8x, 4.7GB, 120 min. DVD-R recordable
sorry if im frustrating you,obviously im very green at this (newbie) -
Heres something else i found!
when i put the dvd i made in and opened it with dvd decrypter,it shows region 1,2,3,4,5,6,7,8. ok now in my standalone dvd manual it shows this:
[Discs that cannot be played}
2.6 & 5.2 GB DVD-RAM, 12cm (5")
3.95 and 4.7 GB DVD-R for Authoring
Unifinalized DVD-R recorded on other equipment
PAL discs (you can still play the audio on DVD-Audio)
[/u]DVD-Video with region number other than "1" or "ALL"
DVD-ROM,DVD-RW,+R,+RW,CD-ROM,CDV,CD-G,Photo CD,CVD,SVCD,SACD,MV-Disc,PD,Divx Video Disc,ect.
ok now is the region number screwing me up you think? if so how do i change it or what can i burn with to fix it..i f you can direct me to where i can find a topic on this that would be great ,i dont expect anyone to start writting a "How to" for me ,im not sure where to look if that might even be my problem. thanks again -
region 1,2,3,4,5,6,7,8 should equal all, I think.
If you rip with DVDDecrypter, it defaults to "all regions" but you can force it to set a certain region if you want - like 1 in your case. That might be the problem, but then again the line: 3.95 and 4.7 GB DVD-R for Authoring seems very strange!
/Mats -
Originally Posted by mats.hogberg
oh well! thanks anyway. im so #$%$%^ frustrated i could just S*#T
iv got 4 dvd players and the only one that will play it would have to be the crappiest one that has hardly any options. im going to buy a surround sound hoe theatre system and i didnt want to have to make sure the dvd player would play svcd or vcd since it doesnt seem theres alot of players that support that format.atleast not when your looking for home system that has dvd player included,but it looks that way,im tired of sitting at this comp. and looking up post after post ect., besides the wife and kids are getting a little upset now
thanks again -
Originally Posted by lowrunner
Could it be because they need to be finalized?
Standalone player that will play ISO images of DVDs
By whatever911 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 30th Sep 2011, 11:58 -
various movie files converted to play on dvd player
By SPORTSGUY88 in forum MacReplies: 4Last Post: 3rd Aug 2010, 10:25 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
DVDs will not play in my standalone Onkyo player
By isuzubuddy in forum Authoring (DVD)Replies: 8Last Post: 16th Nov 2008, 17:37 -
Why can I not burn DVDs that play in my standalone DVD player?
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 18th Sep 2008, 14:05
