Does anyone know how to convert vids in mpg or avi format into .3gp format, the format used in mobile phones. I think 3pg is a form of .mp4
Any help would be great!
i tried the secret forum search function and found this tool
http://www.forum.nokia.com/main/0,,034-63,00.html
in https://www.videohelp.com/forum/viewtopic.php?t=177466&highlight=3gp -
The format needs to be .avi...IMPORT your avi into QuickTime (full) then EXPORT as a 3G (3GPP) and set the resolution to your phones res.
Then WAIT....... -
Xilisoft 3GP Video Converter is a very easy-to-use tool, search it on the site.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
i try those before and guess what, it says something about the frame rate is too high. I set it to frame rate to 1 and it still says the same thing.
Any suggestion? -
What did you use to convert? I've been successful with 3GP Converter and 15/12.5 fps (half source frame rate) for my SE 550i.
/Mats
WMP11 plays .wmv, .avi, .3gp no problem but won't play .mpg?
By billman in forum Software PlayingReplies: 8Last Post: 8th Feb 2010, 17:19 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 17:51 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 15:58 -
DOS multiplexing for DivX and/or other MPG?
By Figge in forum Video ConversionReplies: 2Last Post: 25th Mar 2009, 02:55 -
3gp to avi decent quality requires iTunes, Dr DivX and Virtualdub!
By Dannyfoster in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2007, 15:51
