  1. I ripped and backuped Shrek 2 on Ritek G05 DVD-Rs. It plays perfectly on my standalone dvd player (Zenith DVB318), but when I play on my PC DVD Drive (Optorite DD1205), and I get to the menu screen and select "Play Movie", I get the little snippet with Donkey, but then it doesn't do anything after that. When I try to press play, it goes back to the beginning with the splash screen. BTW, I'm using PowerDVD in Windows ME.
    Note that I've never had a bad burn yet, and this one is merely a minor issue, as it does play on my normal DVD player.
  2. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    just reburn it and see if it does it again. that would be the best place to start
  3. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Did you remove all PUOs? Sometimes it can be the reason.
