I just ordered a Region 2 DVD (it's not available in U.S.) and would like to play it in my Daewoo DVG 3000n on a Sony XBR TV. I can change the Daewoo to Region 2, but I forgot about the PAL format. I'm worried the TV won't play PAL - should I be concerned and cancel my order before it ships or is this an easy fix?
look in the specs of you player and tv.. my player plays both pal and ntsc and the ntsc tv plays them.. BUT if you have trouble you could back it up and re format to ntsc.. there are guides here for that..
I'm moving this to DVD Players ....
Hi
If you can make the player region free it prob. will also convert from pal to ntsc, which if it does, you don't have to worry about the tv as it will already be an ntsc signal coming from the player. -
Thanks everyone. I read a bit more about my DVD player and it's possible that it will do the conversion for me (it looks like a couple of the user reports show success.). I will post more if/when I find out.
Convert SONY CAMCODER PAL to NTSC
By bkdomrep in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 26th Sep 2013, 14:05 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
will a NTSC sony FX1 work in australia were we use PAL?
By gogofilms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2009, 17:57 -
NTSC to PAL ? Sony CX-995V
By LundJepsen in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Feb 2009, 02:23 -
Sony KDL 26S3000 NTSC to Europe's PAL
By Konstan in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2008, 12:12
