  1. I usually just do passthrough when I'm encoding tv episodes with 5.1 sound, but perhaps I should reencode the AC3 5.1 audio track if I can lower the bitrate without appreciable quality loss.
    What is the suggested bitrate for a 5.1 track? I notice on DVDs it is often 448kbps.
    Should I stick with 48000, and CBR when encoding 5.1 AC3?
    Cheers,
    Bruce
  2. The recommended bitrate for 5.1 ac3 is indeed 448 kbps.
  3. what file size are you going for? 2cd? 1 cd? most hdtv caps use a 384kbps data rate, which imo is just perfect. Anything lower than that and you will start to see a loss in quality, especially since you are re-encoding. I would just keep the ac3 at 384, and fit the hour of video on the other 600mb of the cd.
