I'm new to capturing video on my computer...have previously always done it on a DVD recorder.
I just bought a new Dell Dimension 8400 3.2 ghz computer for video editing.
Is this video card enough for video editing? Should I upgrade and to what should I upgrade (where to buy too)....Thanks a bunch!!
128MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon™ X300 SE
If you have more time to help me:
I have 1gb ram, 160gb hard drive (250 external) Is this also enough for video editing. What would you upgrade?
Thanks again.
Andry
Panny E80H & Sony DVD300 Camcorder -
looks like you have more than enough puter power. vid editing really doesnt depend on your GPU alot has to do with cpu. your setup is more than fine
You're okay for video, HDD wise but I would get an larger internal HDD either Serial ATA or Ultra ATA 133. I have 300GB for DVR. I use Radeon Video and Pinnacle PCTV Pro Stereo Audio/Video Capture Card. Oh yes make sure you have plenty of fans in your PC case. As you start to doing your recordings the Video / Capture cards do get hot even if they have their own fans.
Check your DELL and see if there is a case intake fan air in ---->
I know they have case out take fans <----- air out ----->
If you got space for two large 92mm fans buy them you'll need it!
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 03:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
HIS 9600pro ATI 128Mb AGP - driver installation ???
By blinky88 in forum ComputerReplies: 6Last Post: 22nd Sep 2009, 05:52 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum Capturing and VCRReplies: 14Last Post: 18th Jan 2008, 22:26
