  1. This is what i want tolearn how to do, hopefully you pros can help:
    1. Put a dvd that i own onto my computer, make it one file (not separate vobs), and make it around 1 Gb or less.
    2. Put the family guy dvd set i own onto my computer and make them smaller than a Gb an episode. I tried xilisoft video converter but it used the french audio track instead of english. I didnt see an option to change the audio tracks. I dont like dr. divx, are there any others like it though?
    -Thanks People
    Pros don't use divx.
  3. Originally Posted by lordsmurf
    you heard it now you are all set
    There is many guides on this just look over in the menu..
